  • 429 Vote(s) - 2.83 Average
Photocells
Hi, just connecting a CB11 with the 1 set of cells supplied in the kit.
I am getting red flashing leds and the gate motors are turning but only one way?
I have the cells sat about 3 ft from the entrance (so if car is exiting drive and sat waiting, gates will stay open) and opposite each other.
The only other things currently connected are aerial / flashing beacon.
Can anyone advise on what my dipswitches should be set on and what i am doing wrong, the fault seems to be coming from the photocells is there anyway to check these ?
I have used CAT5 cable for the cells.
Or am i just not ding the set up procedure correctly ?
Any help much appreciated.
Regards,
Grant
Hi, you should have your photocells connected to the OP/CL and COM. you need to turn the power off, put a jumper over "learn failsafe photocells" then power the board back up and remove the jumper.
this should learn your photocell configuration.
you then need to learn the gate setup using L1.
See attached file for more information
crafty Wrote:Hi, just connecting a CB11 with the 1 set of cells supplied in the kit.
Regards,
Grant
.doc   CB11 FAQ.doc (Size: 56.5 KB / Downloads: 1,384)
  Adding Extra Photocells To CB22 Onoff 0 7,646 06-08-2020, 01:01 AM
Last Post: Onoff
  chamberlain photocells wlehane 3 33,491 02-09-2019, 10:00 AM
Exclamation lift master SCS300 - photocells Willow 1 13,285 14-07-2016, 09:16 PM
Last Post: Willow
Exclamation lift master SCS300 - photocells Willow 0 9,888 13-07-2016, 11:19 AM
Last Post: Willow
  cb24 photocells devonaloan 1 13,641 28-11-2011, 05:57 PM
  CB24 Kit with a single set of photocells JD1765 1 23,109 07-06-2010, 10:04 AM
  Wiring Photocells on the CB11 control board Sparky 2 25,775 28-06-2009, 10:19 PM
Last Post: Sparky
  LiftMaster CB11 Board Photocells inder 1 15,600 17-03-2009, 03:38 PM
  SUB300, CB11 Photocells problem oldsparky 1 16,601 09-01-2009, 03:18 PM
