I have installed the easygate under ground system for double gate with CB11 control board . The close , open photo sensors are connected to the correct pins with correct polarities . Some how the close sensers do not work .if I swope the two ie with pins 17 and 18 only pin 18 works . The voltage on pins 17 is 24v ac/dc on pin 16 is 15volts ac/dc pin 19 is 24volts ac/dc . This is a new instalation can some one help on this .The sensors are all ok . The setup procedure has been done for the photo sensors .
LiftMaster CB11 Board Photocells
« Next Oldest | Next Newest »
| LiftMaster SL400EVK & 722e Failsafe | Tucks27 | 4 | 2,028 |
26-11-2025, 10:52 AM Last Post: Prem |
| Liftmaster MYQ Internet gateway | koen_dc | 4 | 28,401 |
05-10-2024, 01:30 PM Last Post: Arnold Pow |
| Liftmaster LA400 | Defender | 6 | 23,802 |
03-08-2023, 12:26 PM Last Post: Torantrieb |
| CB11 Multiple Keypad support | Pigsfoot | 1 | 5,732 |
12-08-2022, 08:14 AM Last Post: Michael |
| odd liftmaster scs300-24 | scopie88 | 3 | 22,608 |
13-04-2022, 10:20 AM Last Post: JoeF |
| Problem with delay time CB11 | milan | 2 | 15,519 |
04-10-2021, 01:44 AM Last Post: DesmondVog |
| Liftmaster MYQ Internet Gateway Registration/Connection issues! | Carmody | 0 | 20,351 |
09-03-2021, 02:46 PM Last Post: Carmody |
| Advice on new gate install - LIFTMASTER LYN424 | Leeb | 1 | 24,389 |
22-02-2021, 08:48 PM Last Post: russ |
| Adding Extra Photocells To CB22 | Onoff | 0 | 7,642 |
06-08-2020, 01:01 AM Last Post: Onoff |
| Liftmaster CB1 gates started to open themselves | telnet123 | 4 | 36,612 |
01-01-2020, 09:43 AM Last Post: pronosoft |
