  • 269 Vote(s) - 2.92 Average
lift master SCS300 - photocells
Exclamation
Hi there, first post and looking for some help.
I have a lift master scs300 kit 24v for a double gate installed. The problem I'm experiencing is that the gates will not close. I be read previous threads but can't seem to find the solution.
The only difference I notice is that the chamberlain 771E model photocells stay flashing (pic attached) external to the gate as if there is an obstruction but this is not the case. I opened up both covers to clean around sensor but no change.
I reset system by turning off mains power and removing battery for a while. I turned it back on and then reset gate limits which ended in the closed position. I have a GSM UNIT rang the gates they opened but still will not close.
Can this be as simple as replacing photocells or is there something else I can try?
Thanks in advance
Can the photocells be removed temporarily so that the gate will close ??
  Difference: SCS300, LYN300, and LYN400? DevsAd 3 9,687 02-03-2023, 03:12 PM
  odd liftmaster scs300-24 scopie88 3 22,603 13-04-2022, 10:20 AM
  Adding Extra Photocells To CB22 Onoff 0 7,640 06-08-2020, 01:01 AM
Last Post: Onoff
  chamberlain photocells wlehane 3 33,474 02-09-2019, 10:00 AM
Exclamation lift master SCS300 - photocells Willow 0 9,877 13-07-2016, 11:19 AM
Last Post: Willow
  Opening delay on SCS300 (CB124 board) willows79 0 10,720 02-12-2015, 09:45 PM
Last Post: willows79
  cb24 photocells devonaloan 1 13,628 28-11-2011, 05:57 PM
  CB24 Kit with a single set of photocells JD1765 1 23,088 07-06-2010, 10:04 AM
  Photocells crafty 1 15,669 12-01-2010, 03:29 PM
  Wiring Photocells on the CB11 control board Sparky 2 25,749 28-06-2009, 10:19 PM
Last Post: Sparky
