  • 459 Vote(s) - 2.8 Average
CB24 Problems
Hopefully somebody can help.... Ive got a CB24 control board for my electric gates (liftmaster 400 arms) that I bought from easygate about 4 years ago. They have been working fine for 4 years and then yesterday they just stopped.
Ive checked power to the gates/board and the power and stop lights are steady green.
When i press either the remote or put in the gate code, it clicks as if its going to open, the 'single button' light flashes and then does nothing. Im assuming for some reason there is no power then going to the gate arms although if I undo the locking mechanism on the arms themselves and turn them, the microswitch inside registers as the diagnostic light flashes.
Im not an electrician or expert - i just followed the instructions to get them working originally, so any help or advice would be appreciated.
Have you checked the batteries connected to this board?
Hi, do you have any diagnostic flashes when in normal mode? is there any red lights on the right hand side of the board? if there is you need to check your photocells. Maybe take them apart and make sure there isnt any spiders or dirt.
I have encountered a lot of problems in this field and I have found that usually a power surge freezes out the oir sensors try unplugging them for a while then plugging back in again this works a lot of the time
  CB24 delay to close random fault stuartdsutton 0 10,229 23-09-2015, 11:38 AM
Last Post: stuartdsutton
Rolleyes Chamberlin Liftmaster Professional (CB24 & dual LYN400.24v) SDL 4 33,809 29-12-2013, 02:26 PM
Last Post: Tussun
  Liftmaster Professional CB24 / LYN400 24v - RPM Reversal Error jrhodes310 1 15,513 20-08-2012, 09:40 AM
  Wiring relay to CB24 magga 4 25,684 01-08-2012, 06:35 PM
Last Post: magga
  cb24 photocells devonaloan 1 13,628 28-11-2011, 05:57 PM
  Liftmaster CB24 key switch Mel1962 2 19,048 25-10-2011, 09:52 PM
Last Post: Mel1962
  CB24 Kit with a single set of photocells JD1765 1 23,088 07-06-2010, 10:04 AM
  CB24 / EasyBKA cliff finch 2 17,885 25-03-2010, 09:25 PM
Last Post: cliff finch
  CB24 Stopped Responding TimL 5 29,237 19-11-2009, 05:22 PM
Last Post: adambrown81
  Problems with links "shearing off" gateuser 4 23,608 09-06-2009, 10:04 PM
Last Post: BarkerandGeary
