  • 459 Vote(s) - 2.85 Average
CB24 / EasyBKA
Can someone please tell me how to connect the EasyBKA to the CB24 control panel. There are 11 wires (2 black, a red, a green, gray, violet, white, yellow, orange, blue and brown) What i'd like to know is what wire i put to what connection on the CB24 control board (i guess several of the wires are surplus)
I only want the EasyBKA to be configured for a four figure pin for friends and family to use to open the gate.
As well as another four figure pin to latch the gates open and then the same pin to close the gate ( as in Easygates reply to Malcolm's enquiry dated 03-04-2009)
Thanks,
Cliff.
Attached is a wiring diagram for opening the gates with EASYBKA and also how to latch them open. i will attach quick setup guides for both latching and programming.
cliff finch Wrote:Can someone please tell me how to connect the EasyBKA to the CB24 control panel. There are 11 wires (2 black, a red, a green, gray, violet, white, yellow, orange, blue and brown) What i'd like to know is what wire i put to what connection on the CB24 control board (i guess several of the wires are surplus)
Thanks,
Cliff.
.doc   Quick setup guide.doc (Size: 31.5 KB / Downloads: 2,034)
.doc   Latching with Easybka.doc (Size: 30.5 KB / Downloads: 1,619)
.pdf   easybka cb24.pdf (Size: 9.27 KB / Downloads: 1,464)
.pdf   EASYKA.pdf (Size: 1.1 MB / Downloads: 1,579)
Easygates,
Thank you for the prompt answers to my questions. I'm sure I'll be able to get the gate opening just as I want now.
Cheers,
Cliff.
  CB24 delay to close random fault stuartdsutton 0 10,231 23-09-2015, 11:38 AM
Last Post: stuartdsutton
Rolleyes Chamberlin Liftmaster Professional (CB24 & dual LYN400.24v) SDL 4 33,811 29-12-2013, 02:26 PM
Last Post: Tussun
  Liftmaster Professional CB24 / LYN400 24v - RPM Reversal Error jrhodes310 1 15,515 20-08-2012, 09:40 AM
  Wiring relay to CB24 magga 4 25,684 01-08-2012, 06:35 PM
Last Post: magga
  cb24 photocells devonaloan 1 13,629 28-11-2011, 05:57 PM
  Liftmaster CB24 key switch Mel1962 2 19,049 25-10-2011, 09:52 PM
Last Post: Mel1962
  CB24 Problems andydday 3 22,320 06-02-2011, 11:39 AM
Last Post: Guest
  CB24 Kit with a single set of photocells JD1765 1 23,091 07-06-2010, 10:04 AM
  setting up easybka keypad 1 14,444 12-01-2010, 03:24 PM
  CB24 Stopped Responding TimL 5 29,239 19-11-2009, 05:22 PM
Last Post: adambrown81
