  • 295 Vote(s) - 2.76 Average
Liftmaster Professional CB24 / LYN400 24v - RPM Reversal Error
Hi been running the above system for 6 years now with virtually no problems. All of a sudden I have got the RPM reversal error. Gates open about 20 degrees then stop. Think it is a problem with arm (gate) 2 as it errors if I try to set open limits. If I disengage motors both gates open and close smoothly by hand. Can anybody help !!
All you can do is check and make sure the cable or any cable connections are not corroded or shorting out. Other than that you will need a New Arm as the rpm sensor is embedded inside the motor windings and the motor is very difficult to change. Easier and cheaper soloution is a replacement Arm.
  LiftMaster SL400EVK & 722e Failsafe Tucks27 4 2,018 26-11-2025, 10:52 AM
  Liftmaster MYQ Internet gateway koen_dc 4 28,394 05-10-2024, 01:30 PM
Last Post: Arnold Pow
  Liftmaster LA400 Defender 6 23,793 03-08-2023, 12:26 PM
Last Post: Torantrieb
  Difference: SCS300, LYN300, and LYN400? DevsAd 3 9,687 02-03-2023, 03:12 PM
  odd liftmaster scs300-24 scopie88 3 22,603 13-04-2022, 10:20 AM
  Liftmaster MYQ Internet Gateway Registration/Connection issues! Carmody 0 20,344 09-03-2021, 02:46 PM
Last Post: Carmody
Last Post: russ
  Liftmaster CB1 gates started to open themselves telnet123 4 36,604 01-01-2020, 09:43 AM
Last Post: pronosoft
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 36,268 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  Liftmaster sliding gate Kar1e 1 20,563 08-08-2017, 11:23 AM
