  • 247 Vote(s) - 2.79 Average
green stop light flashing
Hi there
My Cb11 control board is flashing the green stop light so I cant get it to reset whenever i put the jumper in place etc. What can I do to get it to work. They gates worked fine for a while but i got new photcells and when i fitted them and reset as per instructions the green light just flashes and all stops working. Thanks for the help
Guest Wrote:Hi there
Make sure you have a link inbetween pins 19 and 20 labelled 'stop' and 'com'
The stop light should either be on or off, it should never flash. Make sure the link is tight and not lose.
Sorry to annoy you again but the light still flashes. the wire is not loose and everything else seems ok. All the photcell lights flash red also but I take it nothing will function until the green light stops flashing.
Is there a cause of the green light to flash and would the manufacturers have any idea
tef Wrote:Sorry to annoy you again but the light still flashes. the wire is not loose and everything else seems ok. All the photcell lights flash red also but I take it nothing will function until the green light stops flashing.
Try contacting liftmaster on this as i have never come across this problem before.
  Loose gate stop but what wrench to use? bomitie 2 14,386 02-04-2020, 12:06 PM
Last Post: bomitie
  Liftmaster SCS300K - stop/go mtuk100 1 19,014 18-04-2017, 09:31 AM
  LYN300 Diagnostic light flashing 6 times jeff 3 20,828 02-12-2011, 12:24 PM
  edge light tef 1 13,420 12-01-2010, 03:37 PM
  Which lock to use to stop gate moving in the wind marknjo 1 18,963 09-01-2009, 03:20 PM
  LYN400 flashing light, max watts? andy brookes 2 16,054 13-08-2008, 07:04 PM
Last Post: andy brookes
