04-08-2009, 09:58 PM
should the edge light be lit if nothing is connected, does the 8ohm resistor not stop this from lighting up. what led should be lit if only using 1 set of photocells on open/close
edge light
12-01-2010, 03:37 PM
tef Wrote:should the edge light be lit if nothing is connected, does the 8ohm resistor not stop this from lighting up. what led should be lit if only using 1 set of photocells on open/close The 8.2K resistor should be connected, You should have the open/close light off, Open flashing and close flashing. Edge should be off. Make sure you have put the learn fail safe photocells jumper on, reset the board, and removed the jumper to learn the photocell configuration.
Gate Automation and Access Control from EasyGates Retail Store
EasyGates Trade Store for Trade only Smart Home Tech from The Smart and Secure Centre Smart Home News from Smart Home Matters |
« Next Oldest | Next Newest »
| LYN300 Diagnostic light flashing 6 times | jeff | 3 | 20,814 |
02-12-2011, 12:24 PM Last Post: Mark |
| green stop light flashing | 3 | 21,967 |
12-01-2010, 03:39 PM Last Post: easygates |
| LYN400 flashing light, max watts? | andy brookes | 2 | 16,037 |
13-08-2008, 07:04 PM Last Post: andy brookes |
