  • 50 Vote(s) - 3.02 Average
Liftmaster SCS300K - stop/go
HI all,
I have a pair of Liftmaster SCS300K arms containing drive mechanism to open my gates. Recently, one of the arms started to judder and the shaft turns a bit, stops and then turns a bit more, stops and so on, ie: no continuous screw. As a result the gate does not fully open or close. Its as if the cog teeth in the arm mechanism were not fully engaged or the release mechanism comes on and off. Have opened up and cogs all look fine (pic of release shaft attached) but has not stopped opening completely. Motor runs fine if cogs not engaged. Appreciate any advice.
(17-04-2017, 06:05 PM)mtuk100 Wrote: HI all,
i think you have make sure that the lead screw and that smal trolley are working fine . usually the nut in trolley after years got big clearance .
regards
Best RegardsĀ
TomĀ
  LiftMaster SL400EVK & 722e Failsafe Tucks27 4 2,018 26-11-2025, 10:52 AM
  SCS300K Arm Sticking mtuk100 3 6,352 30-10-2024, 10:17 AM
  Liftmaster MYQ Internet gateway koen_dc 4 28,394 05-10-2024, 01:30 PM
Last Post: Arnold Pow
  Liftmaster LA400 Defender 6 23,794 03-08-2023, 12:26 PM
Last Post: Torantrieb
  odd liftmaster scs300-24 scopie88 3 22,604 13-04-2022, 10:20 AM
  Liftmaster MYQ Internet Gateway Registration/Connection issues! Carmody 0 20,344 09-03-2021, 02:46 PM
Last Post: Carmody
Last Post: russ
  Loose gate stop but what wrench to use? bomitie 2 14,370 02-04-2020, 12:06 PM
Last Post: bomitie
  Liftmaster CB1 gates started to open themselves telnet123 4 36,605 01-01-2020, 09:43 AM
Last Post: pronosoft
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 36,273 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
