  • 16 Vote(s) - 2.81 Average
Liftmaster scs
Hi I have a new set of liftmaster scs 324. For some reason I cannot get them to learn the programming for the opening distance. I can get to the point where I open them where I need them
To but they dnt close in the in the final part of the learn mode.  the dgn light is always falshing between 5 lights and 3 lights.
(20-10-2020, 08:56 AM)Athers Wrote: Hi I have a new set of liftmaster scs 324. For some reason I cannot get them to learn the programming for the opening distance. I can get to the point where I open them where I need them
The 3 flashes indicate a wiring issue or poor connection to the control panel on motor 2. This is usually due to the coloured encoder cables being put into the wrong terminals. It can also be caused by a poor joint in the cabling if the cable crosses the road.
If you are using a single motor system you must set the DIP switch 1/2 motor to on. Otherwise the control panel will be trying to detect the second motor which is not installed.
  Liftmaster CB1 / SCS300K - left arm only engages after release then reengage telnet123 2 12,472 10-10-2023, 09:28 AM
Last Post: Matt Turner
  gate stop broke - any spares=liftmaster 300 bomitie 2 13,535 04-05-2023, 04:02 PM
Last Post: bomitie
  what size allen key for liftmaster gatestop and bolt? bomitie 2 21,770 01-06-2021, 04:04 PM
Last Post: bomitie
  Liftmaster scs Athers 0 19,913 19-10-2020, 08:08 PM
Last Post: Athers
  Liftmaster LYN300K, 400K zappahead 1 30,755 12-04-2018, 03:30 PM
Last Post: Tim
  Wanted - Liftmaster SUB300M Motor pigsfoot 1 24,131 03-06-2015, 04:07 PM
  >> Liftmaster CB11 Support Diagrams << easygates 1 32,718 27-04-2009, 12:49 PM
  >> Liftmaster CB24 Support Diagrams << easygates 3 39,812 27-04-2009, 10:58 AM
  >>> Liftmaster CB24 Simple Setup Guide <<< easygates 0 22,792 30-03-2009, 04:27 PM
