  • 23 Vote(s) - 2.83 Average
Nice Robus Don't Auto Close!!!!
Hi freinds .. am new here .. My Robus 600 holds open .. it does'nt close after the pause I set for 5 seconds .. and there are an 8 flashes in the bluebus LED though I don't use it .. I use only normal photocells connected to OPEN slot .. Anyone knows how to fix this??!!!!
Hi Ali,
8 flashes from the bluebus indicates A command that does not permit other commands to be
performed is already present.
Check the type of command that is always present; for example, it could be a
command from a timer on the “open” input.
Do you have anything else connected to the board that could be causing this?
Mike
  NICE gates open slightly then stuck Overthefence 2 4,944 21-05-2025, 10:54 AM
  Mag-lock not activating after close benkay 4 9,696 13-03-2025, 04:19 PM
Last Post: ldkerlukeHome
