  • 26 Vote(s) - 2.88 Average
Nice gates don’t close after the ambient temp is high
Good afternoon
I have a set of Nice gates with a Nice controller (unsure of model number as no literature) approx 18 years old. If the ambient temperature is belowv19/20 Celsius the gates open and close fine. If the temperature increases then the gates open but won’t close until the temperature drops below approx 17/18 Celsius. Has anybody got any thoughts
Howard
All gate equipment has problems, old nice boards suffer from frozen eproms. Gates ease of movement can change over time, so a relearn may be neccessary, unfortunately the board may be locked due to the corrupted eprom chip.
18 years is way past the designed life of Nice equipment, boards suffer from failed/scorched relays, blown capacitors, dry solder joints etc...
Sounds like it requires at the minimum a new board, if 230v motors go with a Beninca brainy 230v board, we've never had a problem with these as a replacement and they're cheaper than BFT. Don't touch the FAAC e145S it still has bugs and requires Simply connect pro to install correctly.
D
(23-06-2025, 03:33 PM)Howard Wrote: Good afternoon
Howard
Hi Howard,
When the issue occurs how many times does the Bluebus terminal flash? It should flash red and give a series of pulses before a brief pause if it is seeing an issue.
  Nice Robus closing after photo Nexur 1 7,836 26-08-2025, 01:47 PM
  Nice LFAB occasionally failing open DaveHG 3 10,318 20-08-2025, 01:52 PM
  Nice Control unit passcode removal Andruelectricgates 1 4,264 17-06-2025, 11:25 AM
  NICE gates open slightly then stuck Overthefence 2 4,940 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 5,013 09-05-2025, 01:07 PM
  Mag-lock not activating after close benkay 4 9,694 13-03-2025, 04:19 PM
Last Post: ldkerlukeHome
  Looking for help with oldschool NICE gate motor gatekeeper 0 5,659 16-02-2025, 05:16 PM
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 3,296 08-02-2025, 07:22 PM
  Nice MC824H Set Up issue dmrgate 2 8,616 10-12-2024, 10:31 AM
