  • 25 Vote(s) - 2.96 Average
Faac E145s help please
When I power up my cb the display shows the following:
"bo" with two blue led's for 5 seconds.
It then changes to blank screen with two blue led's and one red.
Nothing else appears at all.
Can anyone advise on this? Is it possible to do a reset?
Could the board not have any software on it and do you know if it's possible to have faac look at this? It's a new system which I have just installed and can't figure it out.
Thank you for your help.
(23-08-2020, 08:51 AM)pm9020 Wrote: Hello,
I have exactly the same problem. Got the board replaced but it’s doing exactly the same thing. bo and 2 blues and red error light.
Did you get a solution?
There must be a way to reset the software?
One of the topics is not getting loaded in the help file;
It shows: 404: File or Directory not found error?
Is there anything i can do to check whats wrong?
regards,
Raghu
you need to wire the connectors first, it cant see any safetys etc.
then you can go through programming using the 'f' key
Last Post: jonah
Last Post: robhight
Last Post: dennisoates
Last Post: RXH
