  • 16 Vote(s) - 3.25 Average
Faac 415 can't reset from manual to operate mode
Just had to replace large gate post and uninstall then reinstall faac 415.
Getting full electricity through as electro magnetic plate binds very strongly to lock leaf but when gate is activated to open it moves four inches and locks out. The cylinder arm is not retracting and prevents further movement then the system seems to lock out and I have to turn off and repower to reset but it repeats process.
I think the manual override is the problem as I can't reset out of manual. The release system just spins rather than going back to operational.
Hope that makes sense.
Does anyone have any similar experience?
Thank you in advance. Smile
(08-01-2024, 11:43 PM)Stephen Q Wrote: Just had to replace large gate post and uninstall then reinstall faac 415.
Hi Stephen Q, were you able to solve this issue? I'm having the same problem. I had to manually override the opener due to power outage and now it will not re-engage. Any tips would be greatly appreciated.
Thank you!
Last Post: jonah
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 6,896 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,719 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,402 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,435 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 4,006 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,750 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 10,002 22-04-2024, 03:21 PM
  Faac 455d Grantplant 1 8,085 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 6,814 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
