  • 21 Vote(s) - 2.52 Average
Sun affecting gate opener
I have a Liftmaster LA400 gate opener.  My gate opens fine when it is dark or cloudy, but when the control box is in direct sunlight I have to get within 5 feet of the control box and click several times for the gate to open.  All the clickers have fresh batteries.  I had a gate repair man come out and he installed a new circuit board(small one) that he said controlled the remote control access and also a new antenna.
It worked fine, but it was late afternoon when he did it and the sun was not on the control box.  My mistake for not having him come out when there was direct sunlight on the control box.  So everything he did was for nothing except $300 out of my pocket.  The gate guy said he never heard of sun(heat) causing anything like that on a gate opener.  Do I need to install a new (large) circuit board, or just go with a different model gate opener?
The gate is powered by house electricity with its own circuit breaker.  Gate guy also put in two new backup batteries in the control box.  Also there is nothing in the area that would present any rf interference.
I am stumped, because it works fine in the early morning or at night, but when the direct sunlight hit the control box the remote clickers have to be within 5 feet and sometimes right next to the box, and then often it takes several clicks on the clicker remotes.
Thank you very much for any input you might be able to give me regarding this problem.  Sure has me puzzled!!
Hey, I have the exact same issue with my Beninca unit, did you manage to have a resolution?
Thank you!
(02-09-2024, 09:18 AM)ChaoS Wrote: Hey, I have the exact same issue with my Beninca unit, did you manage to have a resolution?
Thank you!
Unfortunately I have not found a fix for the gate.  And I have not been able to find a gate repair person in my area to come and look at it.  I have researched it extensively on the Internet and can find no fix.  If you come up with something please let me know.  Thank you!
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 24,380 22-02-2021, 08:48 PM
Last Post: russ
  Loose gate stop but what wrench to use? bomitie 2 14,366 02-04-2020, 12:06 PM
Last Post: bomitie
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 36,267 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  Liftmaster sliding gate Kar1e 1 20,560 08-08-2017, 11:23 AM
  Operating maglocks independent of gate operator onandog 0 7,882 05-12-2015, 05:05 AM
Last Post: onandog
  LA400 gate openers 24v Tussun 1 14,451 03-01-2014, 12:10 PM
  liftmaster CB11 hold gate open problem sparkey 5 38,373 13-05-2013, 08:17 AM
Last Post: brucekwilles
  Chamberlain Liftmaster gate problem CB1 tentotwo 1 15,826 28-03-2012, 12:55 PM
  One gate acting in reverse marcuswilky 1 14,176 06-01-2012, 09:55 AM
Question gate stops no longer needed? 0 9,702 24-11-2009, 12:07 AM
Last Post: Guest
