  • 314 Vote(s) - 2.82 Average
One gate acting in reverse
I have a problem!
I am using a CB24 controler and 2 LYN400-24 operators.
And I have checked all wiring several times.
My problem is that when I set up the limits the unit accepts them but then when I operate the gates from the closed position only gate 1 opens then when I close the gates, gate 1 closes and gate 2 opens at the same time.
I am puzzled, anybody got any ideas?
You have programmed 1 x gate Backwards or programmed the remote control into just cH 1 instead of CH2. You need to close both the gates manually then program the gates from the close possition.
Press learn limit , then use arrow button for gate 1 to send it open then arrow for gate 2 to send it open then press learn limit then use arrow to close gate 2 then arrow to close gate 1 then press learn limits and all should be fine.
  Sun affecting gate opener ForestRon 2 12,567 02-09-2024, 03:54 PM
Last Post: ForestRon
Last Post: russ
  Loose gate stop but what wrench to use? bomitie 2 14,370 02-04-2020, 12:06 PM
Last Post: bomitie
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 36,268 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  Liftmaster sliding gate Kar1e 1 20,563 08-08-2017, 11:23 AM
  Operating maglocks independent of gate operator onandog 0 7,883 05-12-2015, 05:05 AM
Last Post: onandog
  LA400 gate openers 24v Tussun 1 14,452 03-01-2014, 12:10 PM
  liftmaster CB11 hold gate open problem sparkey 5 38,374 13-05-2013, 08:17 AM
Last Post: brucekwilles
  Chamberlain Liftmaster gate problem CB1 tentotwo 1 15,827 28-03-2012, 12:55 PM
Question gate stops no longer needed? 0 9,702 24-11-2009, 12:07 AM
Last Post: Guest
