  • 280 Vote(s) - 2.85 Average
Daitem SC9200AU Controller to Nice MC824
I've wired the controller up as described in your tech sheet but the controller only opens the gate. I don't have the gates auto closing so would like to be able to close them using the handset. Is this possible?, cheers.
Ok, figured out how to get it to close. I swapped the wire from terminal 14 from "open" to "PP". The gates now open and close ok but the display always indicates the gates as closed. Is there any way to correct this? Cheers.
The daitem is only designed to open a gate, then automatically close it "if set on the gate panel" that's why it cannot tell if the gate is open or closed,
(10-10-2014, 12:59 PM)Shropshire fella Wrote: Ok, figured out how to get it to close. I swapped the wire from terminal 14 from "open" to "PP". The gates now open and close ok but the display always indicates the gates as closed. Is there any way to correct this? Cheers.
