  • 289 Vote(s) - 2.62 Average
Radio control
I have just fitted my gates, and started the gate controllers, I have started the teach function for the gate operation, and completed it as per the instructions, the gates work, the photo sensors work.
I then tried to programme the key fob controllers, pressed CH1, button on the key fob, LED flashes, so the key fob works, do CH2 in the same way, learn programme completes the sequence.
However, the key fob won't work, the photo cells are working, so I am now stuck
any ideas?
Hi Colin,
Make sure your stop circuit is linked out.Im not sure which control board you are using but you need to connect a link between the pin labelled "Stop" and the pin labelled "Com". On the CB11 these pins are labelled 19 and 20.
Hope this helps.
Steven
I have fitted sub300 gate closers and a cb11 controll box one set of photo cells everthing is working and set up but they wont with remote control
David Brisland Wrote:I have fitted sub300 gate closers and a cb11 controll box one set of photo cells everthing is working and set up but they wont with remote control
Hi, Have you set up the photocells? you do this by turning the power off, placing a jumper over the terminals labelled "Save Fail Safe Photocells", then turning the power back on and removing the jumper after 15 seconds.
Check the "Stop" circuit is connected, there should be a link between "Stop" and "Com".
Also check your radio board is plugged into the CB11.
Hope this helps,
  New enclosure for existing control panel BenH 0 2,209 05-06-2024, 12:49 AM
Last Post: BenH
  Fried control board nickfr 3 5,768 22-03-2024, 12:53 PM
  Computer controlled control panel dsbhachu1 0 2,463 18-02-2024, 11:35 AM
Last Post: dsbhachu1
  TC fault code on Q60ar control board Skydive1710 3 10,309 20-11-2023, 03:12 PM
Last Post: NormanY
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 5,977 25-05-2023, 03:55 PM
Last Post: Kaala1
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 12,388 02-12-2022, 02:51 PM
  CAM ZA3 Single control board Rookie 1 11,221 13-04-2022, 11:37 AM
  q60 ar control panel markythesparky 0 3,780 13-11-2021, 06:21 PM
Last Post: markythesparky
  455d FAAC FUSE IN CONTROL PANEL wildfig 0 4,256 04-10-2021, 02:34 PM
Last Post: wildfig
  Genius Brain 17 Control Board - External Open/Close Signal rhennessysummit 1 8,688 02-05-2021, 09:00 PM
Last Post: soother
