  • 324 Vote(s) - 2.82 Average
Proteco RX3 Remote programming
Sad
I fitted at Easter a Proteco Q60A control unit with TX3 remote's, the remote's have worked for about 8 weeks but then both just stopped working, from this I assume the remote's are OK and the fault is with the control unit.
I have checked the readout on the unit and it still retained the programmed remote's in It's memory, I wiped off the remote's from the memory and attempted to re-program, the unit would not be re programmed as when I select rA then tc I then press the remote button, I should get a dot on the readout but nothing appears so there is no point in pressing button C to store, but I have tried it without just for piece of mind.
No broken wires.
The beams and key pad still operate the unit .
Has anyone had this problem or should I just replace the board.
I have re booted the unit and checked the internal fuses, but no difference.
Help...Dave C.
Unfortunatly we dont support Proteco Equipment
contact gatemotors.co.uk, as they are the agentsfor Protect. Their tech helpline is £1.00/min.
JoJo
  Two BFT pairs of electric gates (one remote) Harry44 1 4,693 04-06-2024, 01:30 PM
  Set remote to “only open” gate mark123499 4 10,630 30-05-2023, 01:57 PM
Last Post: mark123499
  Remote only working close up Uphill 0 6,043 03-10-2021, 07:50 PM
Last Post: Uphill
  BFT Deimos Ultra remote problems shaggy 1 14,947 01-05-2019, 09:43 PM
Last Post: ok.dude
Question BFT MITTO REMOTE Battery mk1984 0 10,587 14-11-2016, 01:35 PM
Last Post: mk1984
  Can attempt to add remote but does not open gates conchiron 2 21,068 16-10-2016, 01:31 PM
Last Post: conchiron
  Remote control never detected by Rigel 5 guyvaio 0 8,438 18-06-2016, 06:17 PM
Last Post: guyvaio
  connect Remote control to Arduino dentalan 4 28,043 30-12-2013, 09:17 PM
Last Post: tommysharp
  BFT Barrier Programming EIMB28 4 27,819 24-01-2010, 11:21 PM
Last Post: BarkerandGeary
