  • 490 Vote(s) - 2.95 Average
connect Remote control to Arduino
I have the MITO remote control with four buttons.
I want to connect it with a relay that is controlled from a microcontroller (arduino) All I want is to imitate the button press with a rellay
is the pins 1 and 2 (in the image) the only ones that I should use?
Thank you
Yes. I used to solder wires to those pins and fit Tx inside the RTE button in some strange applications Wink
www.webseb.co.uk
sebabastek Wrote:Yes. I used to solder wires to those pins and fit Tx inside the RTE button in some strange applications Wink
A few hours ago, I risked to burn the remote. I short circuited these pins and the gate opened.
I am going to connect a relay wth thi and If I make it work, I will post some picturesif anyone in interested
Thank you for your response
It works perfectly. Arduino can control now the gate. It is funny.
Is there no way to wire a relay directly into the motor control board? I'm hoping to add our gate to our zwave home automation network.
  Set remote to “only open” gate mark123499 4 10,616 30-05-2023, 01:57 PM
Last Post: mark123499
  Remote only working close up Uphill 0 6,033 03-10-2021, 07:50 PM
Last Post: Uphill
  LED on control board is off Arthur_k99 2 14,893 14-04-2020, 01:41 PM
Last Post: RyanB
  BFT Deimos Ultra remote problems shaggy 1 14,932 01-05-2019, 09:43 PM
Last Post: ok.dude
  BFT LIBRA CONTROL PANEL neilskeates@gmail.com 7 32,371 16-01-2018, 05:13 PM
  BFT Deimos A600 (HAMAL control board) troubleshooting EnricoTerni63 1 20,308 23-12-2017, 05:38 AM
Last Post: TAOZ
  Peccinin remotes with BFT control boards lemafla 0 7,525 09-01-2017, 09:49 PM
Last Post: lemafla
