  • 5 Vote(s) - 3 Average
Daitem sc901 au
Hi trying to work out this system…..bit of a novice so apologies. Need simple wiring diagram how I connect a maglock to this unit…..all help gratefully received
(25-11-2025, 10:39 AM)Ketton Wrote: Hi trying to work out this system…..bit of a novice so apologies. Need simple wiring diagram how I connect a maglock to this unit…..all help gratefully received
When you remove the lid you can see a wiring diagram ion the inside. Mag lock is a little different though as the unit is made to control a latch.
You need a 12vDC HLR wired into terminals 3+4 with terminal 3 being negative, 4 being positive. Your mag lock is then powered through the relay. Once everything is wired in you will need to do the pairing process again for the system to give you access to the above terminals.
Please give us a call on 01225 767 129 if you need assistance.
Installer Manual - https://acrobat.adobe.com/id/urn:aaid:sc...1329ce4e5f
User Manual - https://acrobat.adobe.com/id/urn:aaid:sc...e67c345d56
.pdf   Wiring guide.pdf (Size: 181.83 KB / Downloads: 28)
  Daitem gate control novice help needed... TimRW 0 7,194 29-03-2021, 07:58 PM
Last Post: TimRW
  Daitem intercom not working mikecymru 1 22,665 19-12-2020, 08:56 PM
Last Post: Andy
  Daitem SC900AX Not Working - Help Please! Eskimo 0 27,658 09-04-2018, 08:04 PM
Last Post: Eskimo
  Handset system DAITEM D5131GB Carlo 1 41,020 18-01-2017, 10:49 AM
  Daitem D5300 is it compatiable with SC902AU steve redwood 2 28,599 02-01-2015, 02:55 PM
  Daitem D5731gb system royaugout 1 27,536 02-01-2014, 04:15 PM
  Daitem wireless intercom Mel1962 0 22,763 25-07-2013, 12:49 AM
Last Post: Mel1962
  Daitem CTS5200 Controller babypomdiy 1 24,880 16-05-2013, 10:16 AM
  Daitem d5731gb wireless intercom - Instructions needed Poppet 1 39,929 19-12-2011, 11:33 AM
  New daitem / logisty wireless intercom systems KIT SC902AU BarkerandGeary 3 35,777 18-10-2011, 09:31 PM
Last Post: alban gates
