  • 211 Vote(s) - 3.02 Average
Handset system DAITEM D5131GB
I had trouble exactly same about 18 months ago.
Again I have lost signal to open gates or use intercom
I have fitted new batteries. When I press the little button in the controller and within 20 secs press the external intercom button it beeps as supposed to. Then within 20 secs I press the two buttons on the handset as shown in the handbook
But it does not beep as to show connected.
The small Came remotes work perfect. But not the phone handsets
Any advice please
Thank you
Hi Carlo,
Can you explain what issue you have with the Daitem handset? Does it have speech? Can you open the gate with it? if cannot do both of the above, then i would say that the handset is faulty. You will need to replace the entire daitem system for the new update digital version as they are not compatible with each other.
http://www.easygates.co.uk/wireless-intercoms.asp
(07-01-2017, 08:47 PM)Carlo Wrote: I had trouble exactly same about 18 months ago.
Any advice please
Thank you
  Daitem sc901 au Ketton 1 946 25-11-2025, 01:04 PM
Last Post: GM Techtronics Ltd
  Comelit audio handset no longer opening gates US1549 1 16,229 14-03-2023, 10:25 AM
Last Post: Matt Turner
  Daitem gate control novice help needed... TimRW 0 7,833 29-03-2021, 07:58 PM
Last Post: TimRW
  Daitem intercom not working mikecymru 1 23,663 19-12-2020, 08:56 PM
Last Post: Andy
  Daitem SC900AX Not Working - Help Please! Eskimo 0 28,317 09-04-2018, 08:04 PM
Last Post: Eskimo
  Daitem D5300 is it compatiable with SC902AU steve redwood 2 29,431 02-01-2015, 02:55 PM
  Daitem D5731gb system royaugout 1 28,250 02-01-2014, 04:15 PM
  Daitem wireless intercom Mel1962 0 23,009 25-07-2013, 12:49 AM
Last Post: Mel1962
  Daitem CTS5200 Controller babypomdiy 1 25,231 16-05-2013, 10:16 AM
  Daitem d5731gb wireless intercom - Instructions needed Poppet 1 40,288 19-12-2011, 11:33 AM
