11-09-2018, 02:42 AM
Have Nice Robus350 12 years old, lately (and not all the time) when attempting to open gate it goes forward (closing) and gear spins on track. hitting remote again and it works correctly. Any ideas ??
Robus 350
11-09-2018, 07:30 AM
gear spins on track ? first check gap between gear and track (max gap 3mm) Best Regards
12-09-2018, 01:44 AM
Thanks Tom for quick reply, reason gear is spinning is that gate is closed and cannot go any father. Seems rather than going back, to open it wants to go forward.
12-09-2018, 07:09 PM
(This post was last modified: 12-09-2018, 07:17 PM by Automatic-TC.)
when the gate is closed gear can't spin in normal circumstances ! . Check gap between gear and track when gate are closed . and tell us the tape of limit switch is that magnetic or mechanical one ? Best Regards
13-09-2018, 02:54 AM
Hola Tom,
Your absolutely right, gear cannot spin on its own, it's spinning because motor wants to go forward, when it should be going back (to open). I will check gap in morning (9:50 pm) here, in Puerto Rico> I do have mechanical limit switch, and it seems to click fine and work fine in both forward and back positions. But I do not know condition of contact's, can be pitted or corroded. As I said earlier, it does not happen all the time. I really do appreciate you taking the time to help me.
13-09-2018, 07:29 AM
change contacts for new one . check if is easy to open gate manually reprogram this robus once again Best Regards
14-09-2018, 02:18 AM
HI,
did think about replacing limit switch, could not find in US, available @ European sites, with shipping becomes pretty expensive for a guess. Gap is correct, works fine manually. I will try and reprogram. Have manual, seems a little complicated, but I will try. Thank You again for Your expertise.
14-09-2018, 02:45 PM
programing is realy easy all you have to do is keep pressing 2 buttns for some time and observe led status on panel. Best Regards
« Next Oldest | Next Newest »
| Possibly Related Threads… | |||||
| Thread | Author | Replies | Views | Last Post | |
| Nice Robus closing after photo | Nexur | 1 | 7,849 |
26-08-2025, 01:47 PM Last Post: Jakedugmore |
| Nice Robus 250 HS Fuse Problem | GLM | 1 | 5,027 |
09-05-2025, 01:07 PM Last Post: Aiden Mitton |
| Nice robus not closing | Dantay | 1 | 5,332 |
27-09-2024, 10:17 AM Last Post: Aiden Mitton |
| nice robus D400 smartphone control | YOSH | 1 | 5,609 |
05-03-2024, 04:45 PM Last Post: benbrooks |
| nice robus troubleshooting | tarmongaidon | 7 | 46,132 |
30-01-2024, 05:19 PM Last Post: hasanova |
| Nice Robus RBA3c Wifi Relay Switch Wiring | denis | 1 | 8,093 |
01-11-2023, 09:45 AM Last Post: Michael |
| ROBUS 400 OPEENING CLOSING ISSUES | warren203 | 1 | 5,823 |
08-08-2023, 02:16 PM Last Post: JoeF |
| Robus RB600 | MacMcg | 1 | 7,085 |
28-10-2022, 01:22 PM Last Post: SamA |
| Nice Robus Don't Auto Close!!!! | Ali_1982 | 1 | 7,807 |
03-08-2022, 02:23 PM Last Post: Michael |
| Nice robus 600 | Cole0222 | 0 | 9,927 |
30-04-2020, 08:54 PM Last Post: Cole0222 |
