  • 449 Vote(s) - 2.81 Average
BFT Barrier Programming
Is there anyone who has experience of programming a raised arm barrier using the BFT Proxima Programmer. I need to programme 25 key fobs for a residential car park using the Proxima as we need to be able to delete individual key fobs if need be.
The instructions are a nightmare to use and really not sure where to start.
Can anyone give me a simple step by step instruction to getting started on this?
I have the same problem to be honest... Manual is rubbish
www.webseb.co.uk
!!! Gate and Door Automation Engineers required (London, TW) !!!
I am Sorry i dont have any instructions for the BFT Proxima Barrier system.
Hopefully www.bft.co.uk should be able to help you with some instructions for that system
Just done a install with the proxima it is fun to say the least. ;(
The install was with 60 remotes into 7 different panels and various clonix receivers etc.
Fire me a pm across with any questions I will try my best.
But I agree the manual is no use at all. I had to set mine up at the work shop with all the panels / receivers and remotes in front of me.
As I did it and I figured each bit out I wrote myself my own guide so when I have to do it again I had something to look at. Its not easy enough just to remember unfortunately.
Also forgot to mention that my proxima is only 3 months old but it required a firmware update to work which you may need to do also to make yours work correctly.
Sad Proteco RX3 Remote programming davec. 2 19,241 09-02-2011, 11:05 AM
Last Post: Guest
