  • 27 Vote(s) - 2.81 Average
BFT Thalia ‘Hold Open’
Hi guys,
Got a BFT Thalia L which is all configured up and working fine, but was trying to find a way of configuring them to stay open on the 2nd button press.
As far as I can tell all of the opening modes (Open, Open Timer, Start I, Start E) all open, wait for the TCA timer and then close again.
None of the step by step movement options seem to have a step which makes them stay open either. (E.g. press open when already open)
I’ve wired the 2nd channel output relay to the IC2 input, so just want to find some logic which works for opening on a button press and then staying open until the next press.
I also want to keep the normal button as open -> timer -> close.
Does anyone know if that’s possible?
Thanks!
(02-10-2022, 12:52 PM)hehasmoments Wrote: Hi guys,
Thanks!
By the looks of the manual, IC0 and IC1 can be configured to step by step (4 step). The second command is a stop command if the Step by step logic is set to 0 (4 step).
Hope this helps.
Thanks!
Hope this helps.
Can you please elaborate on the solution? I would be very interested to get it working
Best,
Bart
Thanks!
Hope this helps.
Best,
Bart
Hi Bart,
Thanks for the message,
whilst automatic closure is set you cannot have one button to keep it open, the only method you can try is pressing the button on the remote until the gates reach just before the fully open position and then press the same button to provide a stop command.
Kind Regards
You could activate a "hold open" by interrupting the safety device feed with a switch.
(18-08-2023, 03:30 PM)Caesium Wrote: You could activate a "hold open" by interrupting the safety device feed with a switch.
Great, thank you
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 4,366 03-02-2025, 12:24 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,673 03-02-2025, 11:29 AM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,797 04-11-2024, 05:59 PM
  BFT Thalia no power on accessory ports (50, 51) tjomk 2 4,916 22-10-2024, 02:54 PM
Last Post: Bigmac3112
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 5,031 17-07-2024, 02:24 PM
  Ecosol/Kustos doesn't open and close fully? supremee 3 7,426 09-02-2024, 03:12 PM
Last Post: EdwardBab
  Thalia - Photocell Close J to the D 1 4,054 19-01-2024, 09:54 AM
  BFT LUX2B Intermittent failure to open brookkr 4 13,935 07-09-2023, 08:32 AM
  Set remote to “only open” gate mark123499 4 10,626 30-05-2023, 01:57 PM
Last Post: mark123499
  Thalia P - Wireless control board module mathewnorris22 1 7,087 02-03-2023, 03:17 PM
