  • 25 Vote(s) - 2.92 Average
Ecosol/Kustos doesn't open and close fully?
I am in Australia and I know Ecosol solar is not common in UK.
I am still giving a try if someone here can help with this.
I am running Ecosol/Kustos set-up.
I finished setting with a jumper on for constant power and it works fine with the jumper on.
However, without jumper it opens and closes only 1/3 of full operation.
What may cause this?
(09-03-2022, 11:51 AM)supremee Wrote: Hi,
Hi ,
I am facing the same issue. Did you find the soltuion?
Have got the solution to it. In logic you will have Aux 0/1/2/3 - make sure the value is 6-gate running ( output active while motors are powered)
Happy to observe this! Awesome ideas and the standard of fine detail distributed is incredible!
Thanks and good day!
  BFT LUX2B Intermittent failure to open brookkr 4 13,910 07-09-2023, 08:32 AM
  Set remote to “only open” gate mark123499 4 10,616 30-05-2023, 01:57 PM
Last Post: mark123499
