  • 367 Vote(s) - 2.71 Average
Installing EasyBKA Keypad on motorlift HC300 Double Gate Opener
Can i install EasyBKA keypad on the HC300 Double Gate opener board and run a gatelock as well to secure the gates when closed, i need the lock to release when the code is entered and the gates also to open. Is this possible and how would i connect the wires to the board, numbers will be fine to identify slots, Thanks
Not a Problem the Lock would be controlled by the CB11 or CB1 circuit board for the HC300 and the keypad would be used to trigger the system.
More information on how to install the keypad is at this link
http://www.easygates.co.uk/Support/easybka-cb11.asp
How does the viro v96 lock fit to the hc300 board i'm not sure where the wires go on the board as there is no gatelock pins on the board i don't think. Are pins 10 & 11 for the lock
brom000230 Wrote:How does the viro v96 lock fit to the hc300 board i'm not sure where the wires go on the board as there is no gatelock pins on the board i don't think. Are pins 10 & 11 for the lock
Pins 10 & 11 are the connections for the 24volt electric lock on a CB11 circuit board which is the most common circuit board to come with a HC300 system
  Dead Motorlift ML750 RonBY 1 14,242 20-11-2015, 12:06 PM
