  • 9 Vote(s) - 3.89 Average
Youtube gate specialist broke my module
I have a Nice Module 824H system. I purchased four keypads and learned that each channel can handle two pads, so I planned to watch YouTube to figure out the wiring for the remaining channels. While attempting some wiring, I suddenly blew the module fuse, and the system lost power.
After replacing the fuse, the system thankfully came back online, but the indicator lights were flashing differently. I've been studying the programming notes and details but haven't had any luck resolving the issue.
Complicating things further, two red wires became unplugged. I can't recall if they were connected together into the STOP terminal or if they were split, with one going into STOP and the other into the BUS. I initially split them. When I first had both wires connected to STOP, L1 and L2 were blinking. When I split them, L3 and L4 were flashing, in addition to the BUS light. The flashes do not match the fault codes listed; they just flash continuously without any pause.
To make matters worse, a universal module, a LiftMaster LM850, is also attached. I don't know where to go from here. I've tried resets and reprogramming. The relay only clicks when I use the FOB, and although I hear the click, it doesn't activate anything. I'm hoping someone can provide direction on what I should do before hiring a professional.
Hi, it seems that the YouTube Gate Specialist update has broken my module. It was working fine before, but now it doesn’t function as expected. I can no longer access or process videos properly, and this issue started right after the update. Could someone please check and fix this problem? Thank you for your help.
Due to the nature of this issue being cabling they could be ran to any appliance so this is impossible for us to advise.
A technician would have to come out and take a look a the issue.
Prem
  Looking for help with oldschool NICE gate motor gatekeeper 0 5,659 16-02-2025, 05:16 PM
  BFT Gate Motor CDG 1 4,559 11-06-2024, 09:09 AM
  Gate stuck after opening. rixman 4 8,715 11-04-2024, 08:10 AM
  Replace receiver nice gate Mebeaker 2 10,996 29-03-2021, 03:42 PM
Last Post: Mebeaker
  wifi gate opener xjust 0 6,548 13-02-2021, 10:42 PM
Last Post: xjust
  Wifi Gate Opener - IT4WIFI problems Mehullakhani 0 10,519 12-08-2020, 11:10 AM
Last Post: Mehullakhani
  Aria gate openers and GSM controller Jamie 2 10,388 25-04-2020, 06:19 PM
Last Post: Jamie
  Nice TOO 3000 Gate opener not closing Sully 1 11,406 17-03-2020, 11:34 AM
  NICE 1500A Gate motor and new intercom - fuse blown Phantome46 0 9,436 19-01-2020, 03:37 PM
Last Post: Phantome46
  NIce Aria 400 unable to program gate open/close Telboy 2 16,101 13-01-2020, 03:33 PM
Last Post: Telboy
