07-03-2025, 08:04 PM
The 1.6 amp fuse on my Nice Robus 600 logic board fails as soon as I replace it. Any suggestions on how to diagnose the problem or what could be causing the fuse to blow?
Fuse keeps failing
13-03-2025, 09:56 AM
(07-03-2025, 08:04 PM)kite420 Wrote: The 1.6 amp fuse on my Nice Robus 600 logic board fails as soon as I replace it. Any suggestions on how to diagnose the problem or what could be causing the fuse to blow? Hi, Thank you for your message. I would personally try and take all the connector blocks out that are going to your accessories at the top of the panel. Try putting a new fuse in and see if this blows, it could be back-feed from an accessory causing the issue. If it does not blow with everything out of the panel, try and plug an accessory in at a time until the blow occurs again. Many thanks Ben
Gate Automation and Access Control from EasyGates Retail Store
EasyGates Trade Store for Trade only Smart Home Tech from The Smart and Secure Centre Smart Home News from Smart Home Matters |
« Next Oldest | Next Newest »
| Nice LFAB occasionally failing open | DaveHG | 3 | 10,318 |
20-08-2025, 01:52 PM Last Post: Jakedugmore |
| Nice Robus 250 HS Fuse Problem | GLM | 1 | 5,013 |
09-05-2025, 01:07 PM Last Post: Aiden Mitton |
| NICE 1500A Gate motor and new intercom - fuse blown | Phantome46 | 0 | 9,436 |
19-01-2020, 03:37 PM Last Post: Phantome46 |
