  • 21 Vote(s) - 3.24 Average
My swing gates are stuck at 50% open
Hi my swing gates won't operate and are stuck at 50% open , I learned the CB11 control board and removed the jumper and pressed the L1 button and the photo cells are just flashing and not a sound or movement from the motors on the gates , can you help and point me in the correct direction to fix this issue thanks Joe
(25-03-2024, 12:41 AM)jctrotting Wrote: Hi my swing gates won't operate and are stuck at 50% open , I learned the CB11 control board and removed the jumper and pressed the L1 button and the photo cells are just flashing and not a sound or movement from the motors on the gates , can you help and point me in the correct direction to fix this issue thanks Joe
Thanks for the email.
can you confirm the link is still in the stop terminal and the resistor in the edge terminal.
  Sliding gates are opening/closing like someone is going in /out. gandreja 3 14,729 14-04-2020, 01:45 PM
Last Post: RyanB
  Liftmaster CB1 gates started to open themselves telnet123 4 36,601 01-01-2020, 09:43 AM
Last Post: pronosoft
  CB1 How to learn the gates telnet123 1 18,704 30-04-2018, 01:45 PM
Last Post: Tim
  Gates dont close after being held open jaybee 1 15,810 18-06-2013, 09:23 AM
  liftmaster CB11 hold gate open problem sparkey 5 38,373 13-05-2013, 08:17 AM
Last Post: brucekwilles
  Swing Gate Controller 0 10,777 19-07-2009, 06:50 PM
Last Post: Guest
