  • 25 Vote(s) - 2.72 Average
BFT Lux 2B FC Motor not closing all the way
hello i have a BFT Lux FC and just replaced one of the ram arms (hydronic arms) so everything was already in place i fitted it and its all working fine but when opening as it should then slows down and stops before reaching its stopper on the floor ??
any suggestions when i put it in manual mode it opens all the way and is smooth
(04-02-2022, 04:47 PM)jc.34@outlook.com Wrote: hello i have a BFT Lux FC and just replaced one of the ram arms (hydronic arms) so everything was already in place i fitted it and its all working fine but when opening as it should then slows down and stops before reaching its stopper on the floor ??
Hope you are well. The Hydraulic arms are filled with hydraulic fluid, if the arm is not reaching the full close position, you will need to bleed the arm. Bleeding the fluid will allow a greater open/close distance for the Ram. You should see a bleed screw on your ram arm, only turn this slightly as you do not want to lose excess fluid.
Kind regards
-Jamie
  BFT Eli 250 24V motor running, no movement. Bjorn 1 7,068 30-01-2024, 07:45 PM
Last Post: Peejay
  Phobos motor movement erratic Caesium 1 4,290 24-08-2023, 01:39 PM
Exclamation BfT Sub R - No Closing pressure 1 Leaf Bushpig 2 8,201 23-05-2023, 03:48 AM
Last Post: Bushpig
  BFT SubR not opening/closing sometimes Jimmyboy4 3 8,982 09-01-2023, 10:29 AM
  Gates not fully closing stefen1978@hotmail.co.uk 2 7,782 10-10-2022, 10:07 AM
  BFT Lux 2B FC Motor not opening all the way to stopper jc.34@outlook.com 8 21,177 19-08-2022, 09:30 AM
  LUX G BT 2B not closing properly since manual override swinnie 1 5,301 03-08-2022, 01:44 PM
