  • 25 Vote(s) - 2.52 Average
Logisty LCA01F/LCB01F opens only one gate
I have a powered double-gate and have just completed setting up a radio link between a Logisty LCA01F interior handset and the Logisty LCB01F controller unit. The audio intercom works well, as does pressing the button on the handset with the 'key' symbol to open only the left gate for pedestrians (circled in green in the below photo). However, when pressing the 'gate' button (circled in blue), instead of both gates opening e.g. to let a car in, still only the left-hand gate opens. I know it's not a problem with the right-hand gate motor because the key-fob controller opens both gates at the same time without any problem. So I suspect it's a configuration issue with the handset and or controller, but can not find any clues on how to fix this in the instruction manuals.
Thank you in advice for any guidance.
(17-05-2021, 03:43 PM)Woz1001 Wrote: Hello,
I hope you are well. I recommend getting in touch with Hager via the technical helpline they provide on 0870 607 6677.
- Jamie
  Daitem gate control novice help needed... TimRW 0 7,836 29-03-2021, 07:58 PM
Last Post: TimRW
  New daitem / logisty wireless intercom systems KIT SC902AU BarkerandGeary 3 36,271 18-10-2011, 09:31 PM
Last Post: alban gates
