  • 550 Vote(s) - 2.86 Average
Manual release key
Hi there, first post so here goes!
I need to get a manual release key for my electric gates but cannot identify the make. The release key hole is a hollow cylinder with two ridges inside. I attach some pics which may assist. Could anyone tell me what I'm looking for and where I might source it?
Gerry
Hi Gerry, looks very similar to the Proteco make of gground motor, i do have some release keys in the factory, if you could measure the diameter of the hole to double check the keys i have will fit?
let me know, many thanks
carl
Hi Carl,
That's great - I'll measure the diameter and get back to you.
Cheers and thank you
Gerry
Home IQ Wrote:Hi Gerry, looks very similar to the Proteco make of gground motor, i do have some release keys in the factory, if you could measure the diameter of the hole to double check the keys i have will fit?
carl
Hi Carl
The diameter of the hole on the gate is 15mm.
I look forward to hearing from you.
Gerry
Gerryburn Wrote:Hi Carl,
Gerry
carl
Hi Gerry,
Thats the size of my release levers i have, PM me your address and i will send you one,
thanks
Carl
For you information Gerry
The releases and motors and releases you posted are the saimatic sub motors
as seen here
http://www.theelectricgateshop.co.uk/lat...=&offset=0
replaced 2 of these motors recently
  Help needed sourcing manual release key - Chamberlain HC300 pb3000 1 1,197 10-08-2025, 03:32 PM
Last Post: pb3000
  Liftmaster CB1 / SCS300K - left arm only engages after release then reengage telnet123 2 11,645 10-10-2023, 09:28 AM
Last Post: Matt Turner
  Control panel PSB 2000 who makes this ? Manual needed !! BarkerandGeary 6 39,951 07-03-2020, 10:53 AM
Last Post: Gate-boy
  manual operation wont work brian moffett 1 11,895 15-10-2015, 09:04 AM
Last Post: Dino
  User manual automatic gate MH848 2 20,962 24-11-2011, 02:15 PM
Last Post: MH848
