  • 22 Vote(s) - 2.18 Average
New-build installation planned. Terrified I get it wrong!
Completely ‘new-build’ gate pillars, intercom/keypad, automatic gates and CCTV camera planned for an existing tarmac driveway. Installation advice sought.
Innocent newbie here. Please be kind. A bit of a long post - but hopefully removes the necessity for any obvious questions.
Two pillars, two gates. Light use planned. (Opened and closed - at the most - three/four times a day.)
The two brick/stone pillars will each be built around a steel post, each post receiving a 1.75m-wide (2m high) wrought iron gate.
Built into one of the pillars will be an ‘intercom’ panel; because this panel will face the entrance lane I’d like the solution to incorporate/integrate a CCTV camera which would be positioned to view approaching vehicles. (As opposed to a camera which - as I understand it from the photos I’ve seen - would show little more than the face of the caller.)
We’ll be cutting a trench across the width of the slightly-sloping driveway (not enough of a slope to cause an operational problem) to accommodate the electric supply and take away the surface water. The gates’ (expected) underground operating system therefore won’t be challenged by a water problem.
Preliminary discussion (with the probable gate fabricator) have resulted in me hearing the manufacturer ‘BFT’, and their product the ELI 250, being mentioned, although the gate fabricator sub-contracts the ‘automation’ installation to a preferred specialist associate.
As in ignorance I stumble forward, if anyone can offer any purposeful advice on what I should (or shouldn’t!) do I’d be extremely grateful.
TIA.
(19-11-2020, 03:44 PM)Ian Evans Wrote: Completely ‘new-build’ gate pillars, intercom/keypad, automatic gates and CCTV camera planned for an existing tarmac driveway. Installation advice sought.
TIA.
Here is a link to the BFT ELI 250 Install Manual - might be helpful for your Automatic Gates
  Gate Installation help GrimEire 3 22,788 05-11-2017, 08:51 AM
  Installation corky3377 5 26,270 23-08-2017, 11:09 AM
Last Post: Sheffield1
  Calypso V2 Self Installation leedoncaster 2 16,465 23-01-2017, 12:34 PM
  Add GSM Switch to existing installation? craigside 0 7,369 02-03-2016, 09:25 PM
Last Post: craigside
  ASO plug and sense installation help automatedgates 1 12,654 27-11-2014, 01:03 PM
  Proteco installation in Torquay, Devon James 2 15,401 06-09-2014, 08:59 PM
Last Post: James
