  • 27 Vote(s) - 3.11 Average
Broken bft gates
Hi all,
I am new to this site, so please be kind
This morning my bft swing gates opened fine, but now they will not move!
I have read other posts and the display in the main box says phot
When I press the open button the display changes from phot to strt then straight back to phot
I have cleaned the 4 sensors inside and out and am at a loss
Any ideas would be greatly appreciated
Chris
i would recommend removing all cells and running short leads from the cells directly to the panel.
this most likely will be a short on the cable causing the cells to go open circuit.
if not possible please bell out the cables for a continuity check.
“Phot”is a fault on safety circuit. I’d check each set of beams, one side of each set of beam should be clicking as you cover/uncover. If neither on 1 set are clicking you likely have some faulty beams. Check phot PCBs for corrosion/insects.. they may have blown your accessories fuse. Do you have any lights on any of them?
  FAAC gates out of sync TheDock 1 3,592 21-08-2024, 12:21 PM
Last Post: TheDock
  Rigel 5 , gates won't open Nameloc 4 10,440 04-05-2024, 12:41 PM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 3,158 18-02-2024, 06:29 PM
Last Post: Ivorwindybottom
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 8,256 31-01-2024, 08:22 AM
Last Post: patronsecurity
Last Post: Simon NW
  Nice Gates not closing StuL 1 8,453 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 15,834 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Came gates stuck open. Ring8180 7 30,769 23-02-2023, 01:08 PM
