  • 15 Vote(s) - 2.6 Average
BFT Deimos Ultra BT A 600 + Tbox
I have the following Gate Motor BFT Deimos Ultra BT A 600, It's all installed and working. I have a few programming questions if any one can help it will be greatly appreciated.
The a pair of Thea A15 O.PF Photosells, I'm sure they are wired correctly but they don't appear to function. Do I need to turn them on and if so how.
I have a 2 button remote and the 2nd button is programmed to Channel 2. I want to set channel 2 to operate Pedestrian opening mode. When I press the 2nd button it appears to work as I can hear a relay click when its pressed, but it doesn't operate the gate. how do I turn this feature on.
Tbox is also programmed to channel 2 as well. this makes the relay click when the correct code is entered so it must be a case of programming.
In case it helps I have not removed any of the jumper wires that are preinstalled from the factory in JP8 70-75
Does the TBox have rolling codes ?
Sorry for all the questions I've tried to following the programming diagram in the manual but it's confusing Sad
Thanks in advance
Just an update tommy original post I have managed to sort the Thea A15 O.PF Photosell problem.  It was a wiring problem, D'oh
I still need help with:-
I have a 2 button remote and the 2nd button is programmed to Channel 2. I want to set channel 2 to operate Pedestrian opening mode. When I press the 2nd button it appears to work as I can hear a relay click when its pressed, but it doesn't operate the gate. How do I turn this feature on.
  Question BFT Deimos A400 Makaroni 2 5,061 07-05-2025, 05:58 AM
Last Post: OnionBobo
  bft deimos ultra bt600 error f1 pfloyd 4 8,688 04-10-2024, 03:36 PM
Last Post: pfloyd
  BFT Deimos BT A600 fault Error 10 Airbus330/300 5 15,726 06-03-2024, 11:59 AM
Last Post: GateOpe
  BFT deimos smoke from board stanli200188 1 4,398 05-03-2024, 04:17 PM
  bft giuno ultra bt a20 not closing trackham 0 5,513 21-01-2020, 09:28 PM
Last Post: trackham
  BFT Deimos Ultra remote problems shaggy 1 14,933 01-05-2019, 09:43 PM
Last Post: ok.dude
  BFT Deimos - How to fit a GSM Switch. MyGatesDontWorkSoGood 0 8,449 02-06-2018, 04:46 PM
Last Post: MyGatesDontWorkSoGood
  BFT Deimos A600 (HAMAL control board) troubleshooting EnricoTerni63 1 20,308 23-12-2017, 05:38 AM
Last Post: TAOZ
