  • 51 Vote(s) - 2.92 Average
Swing Gate arm not moving!
    I’ve just joined this forum minutes ago and having some problem with the actuator arm of the door gate. At first the door wasn’t closing properly on the right side, I thought by moving the screw ballnut ( attaches to the door bracket) rotate it manually so that it pushes out which eventually shut the door properly but as soos as I’ve done that the electric motor don’t rotate, I had even swap the electric motor with the other actuator and still does not turn!!, please help!.
The controller is from CAME.
Thanks,
IHere are some pictures of the controller and actuator:
[Image: IMG_9811_zps53rbveha.jpg]
[Image: IMG_9821_zpsamvn92vy.jpg]
1)check whether the voltage is supplied to the motors after you pressed remote control
2) check capacitors
(18-01-2019, 11:31 PM)Automatic-TC Wrote: hi
1)check how affordable these amazing probiotics for gut health are and whether the voltage is supplied to the motors after you pressed remote control
2) check capacitors
How do you make sure that the voltage is supplied to the motors after pressing remote control btw?
Hi!
(13-02-2019, 02:55 PM)Stacker Wrote: How do you make sure that the voltage is supplied to the motors after pressing remote control btw?
Can you hear your motor moving but it isnt engaging the drive shaft?
If so check your capacitors.
To also check your voltage you would need a Voltmeter.
If not possible look for signs of power Ie. LED's or some sort of movement.
Also check your panel and remove anything from the stop input to see if it works then if it does there is a fault in this input whether it be a short in the cable or so fourth.
  BFT swing gates pushing closed instead opening Marc 0 3,564 08-09-2024, 06:33 PM
Last Post: Marc
  Gate sensors does not work when raining vanbinh 5 21,447 14-06-2024, 12:13 PM
  Could Someone Give me Seeking Advice on Gate Installation for Home Security? tysonzach 0 3,234 13-05-2024, 06:49 AM
Last Post: tysonzach
  nice gate openers John Thorpe 1 10,014 19-08-2022, 03:14 PM
  CB11 gate opener testing me!!!! lou trudge 0 7,966 22-12-2021, 10:40 AM
Last Post: lou trudge
  Gate Rail Sweeper/Brush Privateersman 0 9,454 10-02-2020, 03:50 PM
Last Post: Privateersman
  GIBIDI gate motor closing problem davidcunningham 0 11,657 26-04-2019, 08:20 PM
Last Post: davidcunningham
  Help identifying electric gate fob Nick180582 5 30,085 22-10-2017, 01:22 PM
  Diatem Gate Keypad - removing cover hazel.luskin@gmail.com 0 9,402 20-05-2016, 11:28 AM
Last Post: hazel.luskin@gmail.com
  electric gate servicing sparkey0151 1 15,934 02-07-2015, 12:57 PM
