  • 102 Vote(s) - 2.68 Average
Strange gate opening issue (NICE)
Hi, I fitted a set of NICE POP/HOPP gates about 5 years ago and they have been working very well since then.  This week a fault has developed which I just can't fathom.
The LH gate has stopped opening.  It closes fine but won't open.
The RH gate opens and closes correctly in the pedestrian mode but when I try and open both gates for the car, the RH gate opens first (fine) but when it gets to the point where the LH gate should start to open, the system stops and I get an 11 flash error code.  The manual only lists faults up to 9 flashes!
I have cleaned and checked the wiring between the two motors.
Disconnected Bluebus sensors for a trial - no difference.
Removed and cleaned the pins of the POA3 control unit.
Finally, I reset the system to factory settings and tried to get it to ‘Learn’ again both in Auto and Manual modes.  That all worked fine until the LH Gate was asked to open, then the system stops.
The gates are on flat level ground and both swing freely when the motors are disengaged.
I spoke to someone at NICE UK tech support who suggested the 11 flashes 'might' indicate an open circuit or loose connection on the slave motor but I can find no evidence of this.  If that were the case, then wouldn't it affect the closing of the gate also?
Can anyone shed any light on this for me please?
Regards,
Oscar
have you checked resistance on that wire ? I mean motor wire
Hi, thanks for the reply. I haven't got an actual number but I have tested the wire between the two motors with the multimeter and the wire appears to be good.
You may want to run a new cable above the ground to completely rule out the cable and see if this allows the motor to run. This would be for testing purposes only. If the fault persists it could be another issue, possibly a panel fault.
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 58,168 03-12-2025, 04:18 PM
Last Post: StefanP
  Help me identify this mystery gate opener alpha 5 4,912 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 1,878 11-11-2025, 04:41 PM
  BFT Demios A600 bAr issue Rohbot15 2 1,810 15-08-2025, 01:41 PM
  BFT Deimos issue erickavo 2 2,760 09-07-2025, 11:34 AM
  Peculiar automatic gate behavior Gatefreak 1 4,890 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 4,529 28-03-2025, 03:15 PM
Last Post: mitasali
  Nice Swing Gate Opener nicenotnice 0 4,428 18-03-2025, 06:40 AM
  Nice wingo 5400 and MC800 engrbhadz 0 2,134 18-03-2025, 05:53 AM
Last Post: engrbhadz
  came bx-b clicking & not opening misssmith 1 3,027 13-03-2025, 09:57 AM
