  • 77 Vote(s) - 2.81 Average
Hi All BFT ALTAIR-P gates not closing
I installed these double gates some years ago.
Recently the customer had a power failure.
The gates stopped working so I reset the control panel.
Everything worked fine as I tested the gates by opening and closing.
Then the gates refused to close.
When I pressed the remote button both gates continued in the opening mode.
I am aware that the relays on this panel can give problems but would like to hear your thoughts.
The control panel is BFT ALTAIR-P
The motors are 240v and if I reverse the wiring the gates close but will not open
Sad
Michael
  FAAC GATES NOT CLOSING Slick19000 0 5,574 21-07-2021, 01:45 PM
Last Post: Slick19000
  GIBIDI gate motor closing problem davidcunningham 0 11,359 26-04-2019, 07:46 PM
Last Post: davidcunningham
  Just found you my gates are stuck open bomitie 1 10,282 30-04-2018, 01:56 PM
Last Post: Tim
  Bft gates (im not technical) chriscovbft 1 11,657 12-04-2018, 03:52 PM
Last Post: Tim
  Failure of Swing Gates to Close Auto A C John 1 11,960 28-09-2016, 09:23 PM
Last Post: MWJONES
Wink Geniss Gates with Genius BRAIN 03 Control Board 4LPS 3 22,729 10-08-2015, 09:31 PM
Last Post: 4LPS
