  • 386 Vote(s) - 2.78 Average
cb11
as an experienced electrician first attempt at swinging gates using one set of photocells inside gates following installation guide i connected them to open /close terms continued set up gates opening and closing on L1 but when i went to use transmitter nothing happens iknow i have teached trans properly and think my dips are set ok any help would be appreciated thanks
Hi, Have you set up the photocells? you do this by turning the power off, placing a jumper over the terminals labelled "Save Fail Safe Photocells", then turning the power back on and removing the jumper after 15 seconds.
Check the "Stop" circuit is connected, there should be a link between "Stop" and "Com".
Also check your radio board is plugged into the CB11.
Hope this helps,
  CB11 Multiple Keypad support Pigsfoot 1 5,728 12-08-2022, 08:14 AM
  Problem with delay time CB11 milan 2 15,514 04-10-2021, 01:44 AM
Last Post: DesmondVog
  LiftMaster SUB300M + CB11 fault jonesy1991 0 12,649 25-01-2016, 02:51 PM
Last Post: jonesy1991
  CB11 controller BrianP 2 17,563 16-09-2015, 08:58 AM
Last Post: Gateguy
  liftmaster CB11 hold gate open problem sparkey 5 38,375 13-05-2013, 08:17 AM
Last Post: brucekwilles
  Problem with CB11 Board Michael 1 14,431 08-05-2013, 11:32 AM
  230v Lyn400 CB11 Board Capacitor req. redbluetwo 5 28,360 11-10-2011, 01:11 PM
  CB11 control box Intercom release button not working Moreteyne 0 10,698 14-09-2011, 03:14 PM
Last Post: Moreteyne
  CB11 Programming Problem dwanee 1 14,592 19-04-2011, 03:59 PM
  CB11 Fault ! stone acre 0 9,519 28-06-2010, 01:09 PM
Last Post: stone acre
