  • 184 Vote(s) - 2.96 Average
Gibidi electric gate opening
I have a set of Gibidi operated electric gates at my property and they are closing in the wrong sequence - the gate that should close first seems to be operating slower. This then obviously means they will not open correctly so they are stuck on manual at the moment! I would be very grateful if anybody could help me with what may be causing this!!
(25-03-2017, 09:37 PM)sgh123 Wrote: I have a set of Gibidi operated electric gates at my property and they are closing in the wrong sequence - the gate that should close first seems to be operating slower. This then obviously means they will not open correctly so they are stuck on manual at the moment! I would be very grateful if anybody could help me with what may be causing this!!
can we have more info , control board name ?
switch off the power
open them manually max you can
check if each wing gate opening with no resistance
switch on power and use handset to close
Best RegardsĀ
TomĀ
  GiBiDi timing setup high-beeches 0 11,998 22-08-2018, 10:57 AM
Last Post: high-beeches
  GIBIDI wiring... HELP gateman 1 17,029 20-05-2013, 09:39 AM
  Gibidi ram slow djpitt 1 16,559 14-09-2012, 03:24 PM
Last Post: BarkerandGeary
  gibidi rams 1 16,143 18-09-2009, 02:50 PM
