  • 240 Vote(s) - 2.76 Average
BFT Deimos QSC D not accepting new mitto remotes
I've followed the Deimos manual to add new remotes but my unit doesn't seem to want to record either of the key/channel assignments I set.
I can read the setup of my existing remotes (e.g '04t1') but for the new ones, no matter how many times I try to add, they just read the blank 'Ko'.
The unit also has a clonix 2 receiver attached. Would be grateful for any input on how this affects the setup? As it'a a unit I've inherited I don't have the original remotes, only number 4 and 5 working(both channels).
Would be grateful for any advice.
When programming the Mitto in to Deimos system can you confirm you are pressing the secret button? this is done by holding down the two buttons on the remote.
If you are, can you tell me how many remotes are already programmed into the system?
I'm definitely pressing the hidden button. I have the egg shaped Mitto remotes that need you to press the internal button with a thin screwdriver. On the Deimos BT QSC board, it recognises the hidden button being pressed on the 'Add Start' menu, but always just shows 'Ko' after subsequently pressing T1.
If I read the two working remotes on the QSC board they are 04t1 and 05t2 (second functions are programmed to switch a relay also).
On the Clonix, which is wired to the QSC via terminals 13(Blue) 12 (Brown), when I try to program by pressing the SW1 button, it starts blinking, I press the hidden button until LED remains on, then I hit T1 and the LED just goes out. Nothing is stored however.
Best regards,
Turned out to be a couple of old remotes not working. New ones work great. I programmed via the QSC board for both function 1 and 2. No idea what the Clonix is doing on this installation I've inherited!
  BFT Deimos issue erickavo 2 3,247 09-07-2025, 11:34 AM
  Deimos BT 400/600 error codes orange 0 6,144 07-12-2020, 09:36 AM
Last Post: orange
  BFT DEIMOS BT Programming issue dawoodejaz@hotmail.com 0 6,585 28-11-2019, 12:11 AM
Last Post: dawoodejaz@hotmail.com
  BFT Deimos BT Error Codes rajesh 1 21,687 05-06-2017, 11:07 AM
  daitem handset faac gates & remotes doon1968 0 9,007 28-08-2016, 05:12 PM
Last Post: doon1968
  BFT Deimos QSC D second function relay for external lights roadrunner 0 7,385 08-08-2016, 05:42 PM
Last Post: roadrunner
  BFT Deimos QSC D LED display stuck on 'cLS' roadrunner 1 11,536 01-08-2016, 08:45 PM
  Programmable remotes David Etra 3 19,856 22-07-2015, 10:14 AM
  Gate remotes stopped working Steviev1 1 17,746 03-01-2015, 12:01 PM
  Proteco gate code remotes stroller 1 16,694 12-06-2012, 09:50 AM
Last Post: Proteco_UK
Users browsing this thread: 3 Guest(s)
