  • 238 Vote(s) - 2.97 Average
Motorlift ML850 Reverses on close. LED flashes 11 (!) times.
My 8-year old ML850 is starting to give me a problem where it reverses about half a second after it reaches the closed position. As it comes back up, the orange indicator light flashes 11 times which is a bit confusing as the diagnostic codes only go up to 6!
If I reset the travel limits & force, it'll behave itself for another couple of opens but then revert to opening as soon as it hits the bottom. Checked all the usual stuff, no debris, safety beam isn't being broken, no binding on guides etc. Have tried powering off the unit to reset it, then resetting travel limits & force but the problem still remains.
May just be coincidence, but it's happened just at the start of this very cold snap we're having.
Is it likely the logic board needs replacing?
Cheers,
Dan
After 8 years of use, you may find that the white cogs inside the unit are worn and may need replacing. This is usually the symptom shown when the cogs are worn out. You will require taking the cover of the motor and inspecting the cogs.
The replacement parts can be found at the link below.
http://easygates.co.uk/product_info.asp?ProductID=174
Cheers Sav, I'll have a look at it this weekend and report back. Anything to watch for when removing the cover or is it pretty straightforward?
  Motor lift ml850 protector system rondickinson@btinternet.com 1 18,160 15-04-2019, 09:34 AM
  ML850 no longer operates rivergo1d 1 26,678 12-04-2018, 04:52 PM
Last Post: Tim
  MotorLift ML700 or 850 blows plug fuses olliecat82 2 18,105 20-11-2015, 07:20 PM
Last Post: olliecat82
  Motorlift 5000 with bad memory 71MGB 2 19,167 13-03-2014, 12:25 PM
Last Post: 71MGB
  remote will open but not close garage door Sharon OWest 4 27,438 01-08-2013, 10:38 AM
Last Post: DJBenz
  ML850 Remotes don't work huckit P 1 23,682 06-01-2012, 09:59 AM
  Chamberlain MotorLift 5000 Garage Door Opener secash 1 22,639 27-01-2011, 05:55 PM
  motorlift ML 859GB sparkymike 1 14,486 29-06-2010, 04:45 PM
  Where to buy Motorlift Garage Door Openers easygates 0 13,166 13-01-2010, 12:04 PM
  ML850. Setting the Limits Brillopad 2 30,441 03-11-2009, 02:49 PM
Last Post: Doorman
