  • 259 Vote(s) - 2.98 Average
D5131GB FAULT
can anyone help.
I have the Came electric gate system.
I had 5 days away on vacation.
On my return the intercom phone handsets
Will not open the gates. It's as though they have lost the
Signal. Yet the intercom external button rings the phone.
All display is working and shows gates opening when pressed.
These are the Diatem which are used with the Came F1100 system. Yet the small remotes all work and the exterior keypad.
Any ideas.
Thank you Carlo
We have just moved into a new property with the daitem d5131gb handset and have exactly the same problem. Very keen to get an answer to this.
Hi.
I have not had any replies as of now.
I did send the details to Came who replied it probably is the wiring in the control box.
They say prob need to fit all new.
But drastic I thought.
CARLO.
The gates have been ok for 12 month.
Again they have lost connection to the phone handsets. When I press the little button in the control panel and within 20 secs press the intercom button. It connects by sounding the beeps. But then within 20decs pressing the two buttons on the phone intercom the handset is supposed to beep letting you know it's connected. There is no beep. I've checked and renewed the 4 LS20 batteries.
Any advice
Thank you CARLO
the easiest way to chek where is the problem . You have to lokalize wchih pairs of wire is a signal one .If that signal is pottential free(coming from relay ) you can try manuali just cross two wires together for short period of time (1s) just to see if gate will start .
how long thr signal wire is ? over 50m long ?
(08-01-2017, 12:49 PM)Automatic-TC Wrote: hi
if you have ohm meter you should check rezistanca in that wire ,have to by about 1 ohm ,to check this you have disconect wire frome both side ,after cross one side (end) and conect the meter parallel
Best RegardsĀ
TomĀ
Thank you.
I will show this our electrician.
Regards.
Carlo
Have you tried to reprogram to the controller.
http://manuals.easygates.co.uk/daitem-do...on-manual/
See section 5.5
MARK
ACCESS CONTROL LTD
I have tried again today to get the handsets to acknowledge the signal.
It did for one time show the digital screen accept. And when I pressed the button on the external intercom sounded the chimes on the handset. I thought that was success. Then after that it didn't do it again.
I went through the procedure a dozen times trying to connect with no joy.
#9
Sounds like a faulty handset
Access Control Ltd
0800 5677032
www.accesscontrollimited.co.uk
info@accesscontrollimited.co.uk
#10
(08-01-2017, 01:54 PM)Access-Control-Ltd Wrote: Have you tried to reprogram to the controller.
See section 5.5
MARK
ACCESS CONTROL LTD
Hi mark.
The link has not the instructions for DAITEM D5131GB
Thank you carlo
  Lost signal for handsets DAITEM D5131GB Carlo 1 14,421 09-12-2021, 11:46 PM
Last Post: aba gate solutions
  PROTECO Q60S/R FAULT AND INSTALL jeffducati 11 83,067 18-06-2012, 09:58 AM
Last Post: Proteco_UK
