  • 238 Vote(s) - 2.77 Average
HELP!!! CB24 and 400 Arms Problem
Help I
Im going mad! I successfully installed a CB24 connected to a pair of Liftmaster 400 arms that I bought from you & its been working perfectly for 4 years, but a week ago when I pressed any of the openers (remotes, code panel, manual switch or the 'press once' switch inside the control box) the arms start running then quickly stop and reverse for an inch.
I tried disconnecting each arm in turn and the same thing happened - the arm that remained connected moved 2 inches, then reversed for an inch.
Last night I tried taking the arm thats furthest away from the control panel and connecting it directly into the box suspecting that maybe a wire was corroded, but still got the same problem.
So, last ditch attempt to try and work out what was going on, I disconnected one of the arms (the one furthest from the box) and then set the dip switches to 'single gate'. I re-set the opening and closing range of the remaining arm (I had tried to do this with both arms connected with no success) and hey-presto, the single gate opens and closes as normal.
So, Im confused... I guess the only thing left for me to try is to wire in the disconnected arm into the control panel for the arm I know is working to fully rule-out a problem with the arm, but suspect it will work fine. Other than that, Im stumped. Any help really gratefully received!!!
  Photocell Problem marcoos_1 4 29,001 04-01-2024, 10:23 AM
  Master to slave remote problem Dingerb 0 3,933 24-12-2021, 01:26 PM
Last Post: Dingerb
  Proteco Leader N1 problem Luc Bevers 0 4,398 22-10-2021, 09:57 AM
Last Post: Luc Bevers
  Proteco gates with photocell problem. Shane1 0 4,252 09-10-2021, 07:56 PM
Last Post: Shane1
  BFT ULTRA BT A50 problem cayres 0 4,247 13-04-2021, 08:19 AM
Last Post: cayres
  Beninca RI 6E Problem leonardermo 0 6,520 29-04-2020, 08:45 PM
Last Post: leonardermo
  Genius Gate System Problem grasshopper 1 14,914 01-07-2019, 09:39 AM
  Genius JA574 problem jeeter 0 6,794 02-05-2019, 01:13 PM
Last Post: jeeter
  CB124EV Problem biker-boss 1 11,503 11-10-2017, 07:19 AM
  Q60A/R motor problem Johnmc 12 57,722 17-01-2017, 08:15 PM
