  • 213 Vote(s) - 2.76 Average
V2 programing help
Hi!
I need to programe V2 remote (HANDY2). It is rolling code 433 MHz.
anyone have a masnual???? please???
this is the remote:
I believe you have to read the manual of the control panel (if it has a built-in receiver) or the receiver (if it is an external one) of your automation to see how to register the remote with it.
For example:
1) Press the RX key on the control board and keep it pressed for 2
seconds. Led L1 will turn on.
2) Within 10 seconds, transmit by means of the remote
control device by pressing one of the buttons. Led L1 will turn off.
3) Proceed in the same way with the other transmitters.
You should also find in in the manual the procedure for erasing all registered remotes. For example: Press the RX key and keep it pressed for 10
seconds. Led L1 will carry out 5 single blinkings to show that
all the memory content has been cleared.
If I erase the remotes (it'll be good cause one remote's missing) can I programe new (the first one) with this procedure?
  Proteco remote gate programing Krile007 1 22,255 07-02-2014, 10:35 AM
