  • 409 Vote(s) - 2.72 Average
LYN300 Problem
Twice in the last 10 days the following has happened on my 20 month old Easygates LYN300 double gate system.
Gates open normally, gate 1 followed by gate 2, but on closing (not set to auto close) gate 2 closes as normal but gate 1 does not move.
The only way I can get the gates to work normally again is to unlock the manual release on gate 1 and close by hand, re-lock and then the gates open and close as normal.
When this happened 10 days ago I hoped it was a one off but today same again.
What could cause this?
This could be caused by colder weather and the motor needing more force in colder conditions.
First thing to try is to turn up the force on the circuit board and see if this cures the problems.
Also double check you geometry of the brackets to make sure the brackets are installed correctly if not this will cause the arm to wear and eventually fail.
Geometry measurements for the LYN300 can be found at this link :
http://www.easygates.co.uk/24v-geo-chart.asp
Mark
Fault has not repeated (YET!) since my original post. I have re set all the limits and turned up the force setting to 3/4 from just over 1/2.
I have just checked geometry and is as follows: A=12cm B=16cm
Motor is on the outer bracket hole, I have limits set so that gates open to I guess 95-100 degrees.
Does this sound Ok or should I change the position of the motor on the bracket from the outer hole to reduce the B measurement?
Ian
The Geometry you have given is within the chart for the LYN300 so should be fine.
If the system is working fine with the limits reset and the force adjust that may have been the problem
Mark
All has been ok since limit reset and force adjusted.
  Difference: SCS300, LYN300, and LYN400? DevsAd 3 9,692 02-03-2023, 03:12 PM
  Problem with delay time CB11 milan 2 15,517 04-10-2021, 01:44 AM
Last Post: DesmondVog
  Lyn300 lubrication Capricious 5 17,999 08-06-2021, 12:37 PM
Last Post: Capricious
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 36,274 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  CB22 problem??? Bakota 0 10,985 16-11-2014, 02:25 PM
Last Post: Bakota
  Remote problem Nickhh 1 12,454 30-09-2014, 04:48 PM
Last Post: Technologic Systems
  liftmaster CB11 hold gate open problem sparkey 5 38,375 13-05-2013, 08:17 AM
Last Post: brucekwilles
  Problem with CB11 Board Michael 1 14,433 08-05-2013, 11:32 AM
  LYN300/400 thermiclance 0 9,150 29-10-2012, 08:58 AM
Last Post: thermiclance
  Chamberlain Liftmaster gate problem CB1 tentotwo 1 15,828 28-03-2012, 12:55 PM
