  • 340 Vote(s) - 2.71 Average
Door with no springs
We've got a Liftmaster 800A garage door opener which works on a double garage sectional door. At the moment one of the two extension springs on the garage door is broken so the door won't open easily because of the asymmetric pull from the remaining spring and a spring replacement is proving hard to find. I was therefore wondering whether I could disconnect the other good spring and just rely on the garage door opener to open and shut the door, while we sort out replacement springs. The door weighs about 70kg
The Springs on the door are an integral part of the design and need to be there to aid with the lifting of the door. Without the springs the door itself would probably be too heavy for any garage automation kit so you must replace the spring before using the motor to avoid causing damage to the automation kit
  2 x LiftMaster 800 garage door openers Richard B 2 16,581 07-10-2021, 03:54 PM
Last Post: Richard B
  Roller Door Opener LM650 JMB 0 16,902 05-02-2020, 02:38 PM
Last Post: JMB
Rolleyes LM5580 - Door Opens Fully then Drops about 6 inches rossd1983 2 35,153 10-11-2018, 08:16 PM
Last Post: rossd1983
