  • 301 Vote(s) - 2.82 Average
gates keep tripping
hi, why are my gates tripping off the elctric in the house? Any ideas??
If it happens whenever you try to operate them then the problem might be either with the automation control board, the motor itself or the flashing light, if one exists (these are the common cases). A *qualified technician* can run a simple test to see which of the two causes the problem by disconnecting the motor and flashing light and testing the operation of the control board. This is mentioned in order to suggest that diagnosing the cause is usually easy and NOT to encourage you to do any testing/repair yourself.
However, if the problem is independent of the operation of the automation (ie at the moment you connect the power to the motor the breaker is tripped) then the list of potential problem areas would include the cable that provides power to the automation.
In any case, a qualified electrician or gate automation installer should be able to help you.
For Anything electrical to Trip the Power Breaker then you have a cable or motor going to earth or shorting. If it happens when then motors are triggered it is either a motor or cable connectiong them. In either case you would need a qualified gate installer or electrician to identify the problem
  BFT swing gates pushing closed instead opening Marc 0 3,568 08-09-2024, 06:33 PM
Last Post: Marc
  Problems with Came gates ElFinnFlor 1 9,061 07-08-2024, 09:00 AM
Last Post: Skibuddy
  Life electric gates control box Gates head 1 8,109 12-10-2023, 01:09 PM
  Roger Technology Edge1 automatic gates JOKER 1 8,718 08-08-2023, 02:11 PM
  Hydraulic Or Electro Mechanical For Timber Solid Body Gates? geddyMortgage 2 13,656 14-09-2021, 09:35 AM
  House WG2 Gates will not close mousetarget 4 18,646 29-03-2021, 01:40 PM
Last Post: mousetarget
  Keeping gates open Toby 1 15,024 28-02-2018, 12:46 PM
Last Post: Tim
  Reset controll from operating two gates to one andrew.rennie@health.wa.gov.au 1 15,016 17-10-2016, 10:13 AM
  Best choice 4 opposite swinging gates? apeg 1 13,821 28-04-2016, 06:31 PM
Last Post: Russ Dalley
  Moovo gates kev1234567 0 9,835 26-03-2016, 05:28 PM
Last Post: kev1234567
