  • 294 Vote(s) - 2.96 Average
GATE OPENING INDICATOR
Hi All,
Does anyone know of a device,that sounds a buzzer/light at the house when gate is opening?
[/font]P.S.I
Not sure what are you after Evo? Most controllers have some additional outputs activated when gate is in motion or motion+open. Otherwise you can use flashing light output to trigger whatever you need.
www.webseb.co.uk
!!! Gate and Door Automation Engineers required (London, TW) !!!
Thanks for replying,im sorry i did'nt clearly explain what is wanted, the gate is on a farm ,at the main drive entrance ,the farm house is approx 130/150 yards from gate so i dont want to be running a cable from panel to house ,so a wireless device is required for the job operating as following. When gate is opening, a sounder/strobe will sound at the house ,i have thought about a wireless door bell ,connected the bell push, in parallel to the "open/com" terminals in gate panel. So when gate gets open command it also triggers bell push which activates door bell at the house , if ther is a unit that will operate at that distance,?? Thanks Again.......Evo.
[/font]P.S.I
I see! I would go with good range radio Tx and Rx. For Rx you'd have to use aerial on this range. If there is output from the panel then you can connect it directly. If not, then I'd connect relay to trigger Tx. In house I'd use receiver, PSU and whatever is required (strobe or sounder).
In regards to range I'd speak to suppliers but in straight line it shouldn't be a problem for good quality set. Receiver and transmitter IMHO is what you need not a door bell but I guess bell will do the job as well
www.webseb.co.uk
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 58,229 03-12-2025, 04:18 PM
Last Post: StefanP
  Help me identify this mystery gate opener alpha 5 4,927 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 1,883 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 4,898 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 4,533 28-03-2025, 03:15 PM
Last Post: mitasali
  Nice Swing Gate Opener nicenotnice 0 4,432 18-03-2025, 06:40 AM
  came bx-b clicking & not opening misssmith 1 3,037 13-03-2025, 09:57 AM
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 12,937 02-12-2024, 10:40 AM
Last Post: bing
  Gate not closing thronetm 0 4,121 16-11-2024, 09:25 PM
Last Post: thronetm
  Gate kit recommendation electric gate harry 0 3,939 10-09-2024, 03:57 PM
Last Post: electric gate harry
